SHG from july 14th
- DSobserver
- Been thanked: 19 times
SHG from july 14th
Long time that I did'nt play with my SHG!
Ha : our sun looks really sad....
Hb :
Cak :
I've been really surprise to see 3 emission line near Calcium... Any explanation?
And finally He : a disaster, no detail! Any support to help me here?
Hb :
Cak :
- Has thanked: 20962 times
- Been thanked: 10593 times
Re: SHG from july 14th
Nice set of images there!
- p_zetner
- Has thanked: 166 times
- Been thanked: 719 times
Nice images, Vincent. I especially like the H alpha.
I'm assuming the 3 emission lines are (top to bottom) H epsilon, Ca H and Ca K.
To see any surface detail in He D3 requires subtraction of an image made in the nearby continuum.
Peter.
(Wah will probably object to, and repair, the lines / banding !)
Peter.
- Has thanked: 18105 times
- Been thanked: 8942 times
- DSobserver
thanks for your comments!
Here are some answers :
Peter :
never heard about H Epsilon...have you ever try it?
For He D3 how do you substract an image made in continuum
Wah
Indeed I only resize HE D3 quickly without removing the band that I used to remove with Gimp software. Gimp is not as good as PS software that you are used to take...The issue is that I don't have PS...Do you know any freeware for this?
Peter :
Wah
- p_zetner
Hi Vincent.
I've tried H eps but found it difficult to observe much surface detail. I think Wah has imaged this one (?). I know he's done H gamma and delta. In my opinion, images taken in the Balmer lines shorter than H beta look very similar to H beta but with less contrast.
My technique for extracting the He D3: I take a series of images through the region of the He D3 line and load this series, as an image sequence, in ImageJ. I then choose one image of the series (near the beginning or end) and subtract it from all images in the series. Generally, I can detect a couple of images which then show He D3 structure. One of these is then selected to process further. There is usually a lot of noise and image irregularity to deal with. One way to proceed is to use the ImageJ FFT bandpass on each image of the series before subtraction. Sometimes, rather than selecting one image, I take an average over several (this is the case for the latest image uploaded here).
Let me know if this helps.
Peter.
Peter.
- DSobserver
yes it is. As mentioned I only wanted to show you how bad was my He D3 shotWah wrote:Hi Vincent, I think you must have at least rotated or skewed the images from the raw, haven't you?
- DSobserver
Sorry peter, not sure to understand it correctly....p_zetner wrote:Hi Vincent.
Peter.
Would it be possible to clarify it with some pictures?
