Coming back...
Wah
Has thanked: 8 times
Been thanked: 17 times
Coming back...
Post by Wah » Fri May 29, 2020 1:13 am
After a long leave, I am now redesigning the spectroscopes and creating the parts by using a 3D printer.
Some optical glass slits have been used also, I hope the overall image quality can be improved.
Has thanked: 2814 times
Been thanked: 1057 times
Re: Coming back...
Post by Montana » Fri May 29, 2020 7:05 am
Excellent!! I really look forward to your excellent images again :hamster:
Has thanked: 2739 times
Been thanked: 1087 times
Re: Coming back...
Post by marktownley » Fri May 29, 2020 11:27 am
Fantastic Wah! I'm looking forward to the results.
Has thanked: 15 times
Been thanked: 69 times
Re: Coming back...
Post by Merlin66 » Sun May 31, 2020 8:38 am
Wah,
Glad to see you back.
I think 3D printing is the way forward. Paul has been active producing his LowSpec spectroscope design, a great introduction to slit spectroscopy.
Are you going to update your SLM software to allow larger files???
Wah
Re: Coming back...
Post by Wah » Sun May 31, 2020 4:17 pm
Which file format and what size do you need?
As far as I remember, I was using an external library for avi format which cannot handle larger size files.
Then a newer version could handle mono-color ser files without problems (I guess).
Re: Coming back...
Post by Merlin66 » Sun May 31, 2020 11:33 pm
Wah,
I've been trialling a fast frame ASI 174MM camera on the SHG, using the x2 RA speed to reduce acquisition time. ( Using an ROI just enough to get the spectral line, I can get up to 400 fps)
The SER files can be up to 3Gb in size....this seems to be an issue for SLM?
Ken
Wah
Re: Coming back...
Post by Wah » Sun May 31, 2020 11:48 pm
What error did it show? Or it never prompt error when the file is over 3GB?
Re: Coming back...
Post by Merlin66 » Sun May 31, 2020 11:57 pm
I think it just didn't run.....
(Been a while now due to weather and other issues. I could probably find the file on the computer and check if needed.
Wah
Re: Coming back...
Post by Wah » Mon Jun 01, 2020 12:41 am
You may compress and upload the file to google drive or dropbox and let me have a try.
Re: Coming back...
Post by Merlin66 » Mon Jun 01, 2020 1:05 am
Wah,
Give me some time to find the files.
I'll email you when I'm ready.
ken
MERRILL
Been thanked: 6 times
Re: Coming back...
Post by MERRILL » Mon Jun 01, 2020 5:53 am
It looks very nice!
Has thanked: 1153 times
Been thanked: 981 times
Re: Coming back...
Post by Carbon60 » Mon Jun 01, 2020 6:15 am
Welcome back. Looking forward to seeing the results from your new kit.
Stu
Wah
Re: Coming back...
Post by Wah » Mon Jun 01, 2020 11:40 pm
The refill filament has arrived and more parts have been printed out.
Wah
Re: Coming back...
Post by Wah » Tue Jun 02, 2020 10:55 pm
Two improvements:
1. Slit fixing method
2. Print direction
Re: Coming back...
Post by Merlin66 » Tue Jun 02, 2020 11:05 pm
Wah,
The OVIO reflective slit plates????
Wah
Re: Coming back...
Post by Wah » Wed Jun 03, 2020 12:49 am
Not from OVIO, but tailor-made from China some years ago.
Re: Coming back...
Post by Merlin66 » Tue Jun 09, 2020 2:08 am
Wah,
I've sent you an email with the SLiM errors, and sent a copy of the AVI file (930Mb) to dropbox
https://www.dropbox.com/s/rrjtee31vwf1h ... p.avi?dl=0
Ken
Phil Rousselle
Oh, I get it now!
Oh, I get it now!
Been thanked: 7 times
Re: Coming back...
Post by Phil Rousselle » Tue Jun 09, 2020 5:33 pm
Very nice job Wah !
I've also a 3D printer, and it's a very good tool to make parts for SHG
Phil
Wah
Re: Coming back...
Post by Wah » Wed Jun 10, 2020 12:45 am
Wah,
Ken
I just experienced the error myself this morning, and found that it should be a setting problem. I mistakenly set the project as X86 rather than X64, so it could only allocate a very limited amount of memory. I will post a recompiled version later and let you try.
Re: Coming back...
Post by Merlin66 » Wed Jun 10, 2020 12:57 am
Wha,
Thanks for the feedback.
Your continued support for the SHG is appreciated.
Look forward to trying the new version.
Wah
Re: Coming back...
Post by Wah » Wed Jun 10, 2020 1:51 am
https://drive.google.com/file/d/1Gnfkx2 ... sp=sharing
Hi Merlin, are you able to download the file from the above link?
highfnum
Been thanked: 112 times
Re: Coming back...
Post by highfnum » Wed Jun 10, 2020 4:14 am
interesting
Re: Coming back...
Post by Merlin66 » Wed Jun 10, 2020 4:44 am
I’m in transit....I’ll download later when I get home.
Many thanks.
Re: Coming back...
Post by Merlin66 » Wed Jun 10, 2020 6:57 am
Wah,
Downloaded OK
I'll try it ASAP and give you feedback.
Many thanks,
ken
Re: Coming back...
Post by Merlin66 » Wed Jun 10, 2020 10:20 pm
Wah,
Unfortunately it still shows the same error messages.
Looking at the "Unhandled exception" - Object reference not set to an instance of an object
There seems to be references to d:\projects\SLiM_RemovedProcessing\form1.cs.
I assume this was your working directory????
Let me know how I can assist.
regards,
