Appenzellersun, 20th april LUNT LS50F/TZ4 first light
Hi all
finally I found some sunrays. The seeing was not as it should be for a first light, but I had to get it, the first light.
Mixed results. Less good as a PST mod, lack of contrast, uneven field, difficult to get on band, very sensitiv on dust mots, good I had my new flat film ready
- Been thanked: 10247 times
Re: Appenzellersun, 20th april LUNT LS50F/TZ4 first light
Interesting first results, the first 4 are definitely off band. What scope were you using walter?
Hello Walter.
Some real (1) and possible (2 and 3) reasons of this experiment failure.
1. The etalon works in a significantly convergent light beam instead of a native F/109 the etalon was designed for.
2. Uneven illumination is due to incorrect (for your location altitude) etalon performance and therefore you need to
tilt the etalon.
3. If you can't come to the band, this mean that the etalon will work only at higher barometric pressure and lower temperature -
at lower altitude and may be during cold winter in your area.
Let me know the altitude you are living at and what is your typical barometric pressure range (lowest and highest).
My advice: forget this mod. This is for temperature controlled etalons like DayStar or Solar Spectrume or for newer Lunt solid temperature
controlled etalons - all with narrower band wide and unnecessity of the tilt to come to the band.
Valery.
tilt the etalon.
Valery.
Hi Mark, Hi Valery
thank you very much for your Input.
@Mark For the tests I used my TAK 102 f/8 . Yes they are in the redwing , tilting the etalon with the turning weel did not change much. In fact the null position showed at least some Ha structure.
@Valery
well that was at f/32, I can get up to f/40 but will not Change much. I tried f/24 and that was worse
Tilting the etalon did not really improve much. Fact is that I did not reach the blue wing
We are living here at 750 m above sealevel, temperature yesterday was some 18 °C, The usual baromatric pressure is 950 to 1050
I'm not giving up
@Valery
I'm not giving up
- Has thanked: 8418 times
- Been thanked: 8163 times
It will be interesting to see how this progresses, Walter.
Hi Stuart
thank you very much for the motivation
swisswalter wrote:Hi Mark, Hi Valery
@Valery
I'm not giving up
Walter, it seems you need to go high in the mountains, say, at 1500m and up. :^))
To see if you can stay in band, test your LS50F in it's native position (in a front of the scope) and see if you can move the CWL from the red wing to the bue wing.
If yes and all is OK with the etalon, then the problem is in the telecentric rig and in too much widening of the band wide due to converge of the light beam.
And one more thought. May be you are at the blue wing partially capturing the CWL? In this case go to lower altitude and colder air.
Hi Valery
thank you very much for your Inputs. Here the Setup
as the LUNT filter is new and virtually unused I guess it is in top condition. But I'll have a go up front the TAK and we will see.
- Been thanked: 171 times
Got to try these things Walter otherwise we,ll never reach Solar nirvana.
This mean that THIS etalon is not suited for using at your elevation. It is suited better for lower altitudes may be even for sea level.swisswalter wrote:
This is a reason why I asked you if your LS50F for sale (I can buy it for work at seal level where I am living) and I have a LS50F which is better suited for higher altitude. So, lets talk about this in private. May be we will help each other.
The rules:
1. if the air-spaced etalon works fine at a sea level, then it will work worser at higher altitudes and sometime even can not reach blue wing (depends of altitude).
2. If an etalon works fine at higher altitude, it will work worser at lower altitude, because it will require too much tilt and will exhibits banding due to such a tilt.
Walter, I can see way too many ellerman bombs for this to be on band. still a very nice set of images!
Chris
Chris
Chris Schur
Hi Chris
thank you very much. Yes that is top right. We are on the red wings only. That is one of the problem.
Hi Valery
an interesting Point, just swapping the filters. My filter has 7 spacers and yours ? The older ones used to have only 5. Please drop me an email
Hi DerekDerek Klepp wrote:Got to try these things Walter otherwise we,ll never reach Solar nirvana.
thank you so much. I'm with you. Off we go direction Nirwana
Hi Walter, that's a very interesting set-up, it seems a hard work but very promising
Have a question: do you need also an ERF in front of the tube?
Play in the sunshine, we're gonna get over !!
Hi Marcello
thank you very much. Yes you need an ERF. I did put a D-ERF up front the TAK and took out the original ERF of the filter
Thanks Walter
- Been thanked: 4340 times
Hi Walter...
Very interesting filter setup and images form the first light. Lots of wing activity with the Ellerman bombs. Hope you manage to make the system work more to your liking.
Hi Brian
thank you very much for your motivation
Maybe a silly question, Walter, but could the weight of the BF diagonal and camera be adversely tilting the etalon, or preventing it from tilting properly? The torque generated between the front mounting adapter and the rear adaptor, created by the cantilevered rear weight, might be preventing the thumb wheel from properly jacking the gap which normally facilitates tilting of the etalon.
Just a thought.
Just a thought.
Hi Stuart
thank you very much for your thoughts. I certainly have to check that. Exept of the two first extensions the parts are screwed on, so I do not expect sag. As for the tilting of the etalon it selve, it is freely mounted inside the housing not touching or beein torqued by any force to the rear and front adapter. Basically it hangs in the air ;-)
Hi Walter,
No problem. It was just a thought.
I wasn't sure how the etalon was mounted, exactly.
Hi Stuart
thank you very much. I did a quick run today mounting the same filter up front of the same scope. What I couls see is, that the Etalon Comes on band and that it showes what a lunt50 showes, a uneven field. So it is not a matter of sealevel or higher altitude
What Mark Wagner wrote about rear mounted filters at the CN Solar forum.
"Rear mounted filters. The bandwidth of these filters depends on at focal length they are being used at.
If you have a.5Ang filter at F/40 and you use it at F/20 the filters bandwidth will be closer to .9Ang. "
Note, that LS50F etalon is 0.7A at F/108 ! So, at F/30 or so it will be not better than 1A.
Hmmm, I see the point you're making Valery.
There's no easy way to cheat extra performance out of these systems is there...
Hi Valery, Hi MArk
thank you very much for your comments. So we have to pack the LUNT50 in between a collimating system to get decent results , haven't we ?
Yes, but if you need them to work at 100% potentialswisswalter wrote:Hi Valery, Hi MArk
1. real 0.7A
2. maximal sharpness (no spherical aberration, no astigmatism, no field curvature) with Shtrehl >97% for full disk
3. full disk with prominences in Ha in the eyepiece (with binoviewer too)
4. no need to buy any ERF or D-ERF
5. have a 0.5A with no wings, in 5 min (for large scale imaging)
6. Extremely compact
Then this must be specifically correctly designed and made 100% according to the design. Yes, this cost it's money, but well worth it.
Even in our far not rich country, some amateurs who saw it's work, bought it next day. You all already saw the images taken through
such a system.
Valery.
Hi Valery
thank you very much for your Points. Yeah, we know by now how fantastic pics you make with your kit. What does the correktion consist off. What is to do ?
