Appenzellersun, modding a QUARK
Hi cracks
not really , only joking. I will not taking them apart further. So just unscrewed the "loose" parts
the full view
the essentials
the ERF
the telezentric barlow
the Etalon
the Etalon with the heating unit
the full view
the essentials
the ERF
the Etalon
Re: Appenzellersun, modding a QUARK
Nice mod, Walter! Hope it will work even better after this mod.
Thanks a lot for these pictures. Very impressive.
- Peter Williams
:-) you're a funny man Walter, keep up the good work.
Beginner amateur astronomer, keen on solar astronomy.
- Been thanked: 10487 times
Excellent! That's what I like to see, something that is taken apart as soon as it is bought. Just the thing I do too
- solarchat
- Site Admin
- Has thanked: 84 times
- Been thanked: 1384 times
oh boy...
Stephen W. Ramsden
Atlanta, GA USA
http://www.solarastronomy.org
Atlanta, GA USA
Hi Stephen
thank you very much for your comment
Believe it or not, here is the first shot through a modded QUARK used in WL mode
- sullij1
Walter has a point in that extensions may be necessary for some scopes. This is the one I used to get mine going. 2 inch EP to a EP projection adapter. This will negate unscrewing stuff. I have another adapter set-up I will try when weather permits.
Look Up!
- sullij1
It does look like the Quark will lend itself well to getting any screw in adapter to get on the device. A good thing in my opinion, especially when there is a myriad of scopes, telecompressor etc. that will be used with it.
Look Up!
- sullij1
BTW, I opted for the extension because my stock Celestron 102 focuser gets very sloppy the farther rearward it gets. This causes or nemesis Mr. Newton ring to appear. The adapter keeps the focuser travel to a minimum and helps keep the Quark square with the imaging plane. The two compressor screws make me feel better about Quark NOT falling out.
Because of the Quarks ability to "adapt" it "could" become the weapon of choice for a lot of less well heeled imagers.
Look Up!
Indeed. I think the quark will be a hot, just hope daystar can meet the demand and don't end up with long waiting lists...
Hi Joe and Mark
jup there we go with another modding field. We will be having lots of fun. I don't think there has been a gear placed on market and being modded so fast after ist presentation
So guys which do you prefer "prominence" or "chromosphere"
Al
Al
Alan
Hi Alan
at the moment, I would go with the chromoshere model
- sullij1
Doesn't look like any modding needed. It is well thought out and engineered such that any screw on adapter known to man will be able to thread in/on. No doubt the coming telecentric and 2inch EP holder will also just thread on.
Look Up!
- astroshot
- Has thanked: 335 times
- Been thanked: 252 times
Walter,
The Quark looks impressive.
Biggest concern I have is the heating time.
In Ireland, the sky would probably be cloudy again by the time it has heated fully. ;-)
Did you order direct from Daystar or from a European dealer?
Thanks,
Michael.
Thanks,
Michael.
Michael in Kildare, Ireland.
TEC140
Coronado Solarmax 90
Daystar 0.6A T-Scanner
TEC140
Hi Michael
thank you very much. I ordered direct. Concerning the heating up we have almost the same situation here. If you first get the Quark plugged in when you decide to do solar, you should get along. Do not unplug it, otherwise you need additional time until it is on band again
