I'm the Coordinator of the Polisch Solar Observation Section. For my observations I use a 114 x 900 telescope with etched mirrors. Such equipment transmits about 0.8 to 1.4 beams of sunlight. I'm inserting an OIII filter into the eyepiece. The question is this.
Does this filter adequately protect against infrared radiation? I have not found any answer to this and I use this equipment for visual observation of the Sun. Greetings.
Telescope with etched mirrors
- Has thanked: 20813 times
- Been thanked: 10485 times
Re: Telescope with etched mirrors
Greetings Tafig! By etched do you mean the coating has been removed from the mirror?
The comment Hello ! exactly sounds rather a RUDE comment and not needed
I hope I am wrong but it sounds dangerous what you are doing, I certainly would not want to be the one to use it
72mm Ed Skywatcher for Solar
SkyTee 2
Sky-Watcher SolarQuest
Gitzo Systematic Series 5
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
What does this mean ??????????
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
SkyTee 2
ASI 178MM
Daystar Quark Ha
WO Binoviewers
Many eyepieces 2"
I think using with a uv/ir cut filter is not a bad idea.
If both mirrors are etched about 4% of 4% enters your eye. OIII normally does not block above 1000nm. I would follow Mark's suggestion.
It's perfectly safe, there are quite a few people who have done it now. The uncoated mirror reflects a similar amount of light as a solar wedge transmits (assuming only the primary is uncoated). Therefore additional ND filtration is required to bring things down to a safe visual level, if imaging is the only consideration the more light the better as exposures will be shorter.
- tafig
- The Sun?
- Has thanked: 3 times
- Has thanked: 1 time
- Been thanked: 2725 times
OIII filters are not all the same. Photographic OIII filters give more protection than visual OIII filters. Still they usually block up to 1100-1200 nm.
Here is the example of the Astronomik CCD OIII :
So, as said before, it is better to associate the OIII with a neutral density filter, and if possible to an IR filter (KG3 or equivalent), in order to have blockage beyond 1100 nm. A good IR filter is the Beloptik IR filter.
