help with stuck threads
- Been thanked: 4340 times
Hi all...
While this isn't a solar scope questions I have run into a problem trying to remove a threaded adapter from my C9.25 reducer and wondered if anyone had any suggestions.
I attached the 2"eyepiece holder to the reduce back in the winter and removed the pair form the scope the other day. I then tried to thread the eyepiece holder off and couldn't budge it by hand (threaded on by hand). I also tried a pair of ratchet straps and have only managed to turn the adapter a few millimeters. It wasn't cross threaded and was on and off a few times in the winter with no problems like this.
The adapter threads off at the ring with the vertical ridges...or it should
My main thought is after warming up the two pieces have expanded at different rates and locked the threads together...but it is a guess. I might try putting them in the freezer and see if they will revert to their winter fit, or apply a dew heater band to the adapter and see if it will expand a bit.
Anyone have any ideas????
- Has thanked: 20442 times
- Been thanked: 10246 times
Re: help with stuck threads
Get it warmed up and give it a go. Have you got a vice / clamp you can put one end in when you use the ratchet strap?
- Has thanked: 1 time
- Been thanked: 2713 times
You can try some drops of teflon oil. Wait one or two days after you drop the oil, then try again.
Mark and Christian...
Thanks for the suggestions.
As it is now, the whole assembly is warm and will not budge so that was why I had considered cooling it again tot eh conditions it was assembled in.
The Teflon oil sounds like a good plan, though not sure where I'll find that locally. I can check around, if not available could other lubricants be applied (sparingly of course)? WD40, cooking spray, etc?
When we have locked nuts and bolts on the boat that we need to shift we always go for a spray of wd40 and leave overnight, does make it all slippy to handle so directed aim in application is prudent.
- Has thanked: 8418 times
- Been thanked: 8163 times
Hi Brian,
I agree with your first instinct.... Cool the whole thing right down to replicate your winter conditions and try then. Differential expansion is the most likely reason they have locked together.
Some oil could also help.
Hi Stu...
I was thinking the same...at least for the first try.
Mark, I just want to be damn careful not to have the WD40 leak on the optics
A project for the weekend by the looks of it.
good point Brian, wd40 and optics is asking for trouble. Binding threads is always a pain.
- Martin_S
- Has thanked: 979 times
- Been thanked: 2992 times
Hi Brian, This might be a last resort solution. Is it possible to remove the lens cells from the reducer?. If so you can then get a shallow bowl of icy water to chill the reducer barrel then get two small hand towels, one dry one to hold the reducer the other one should be a hot damp one one heated in a microwave oven to grip the ring. you need to work fast as you are shrinking the reducer body and expanding the ring . You may have to do this a few times if you only get minimal movement. Just be careful not to scald yourself with the hot towel.
Martin
Martin
Hi All...
Removing the optics might be last resort...god forbid
I plan to put the whole thing in the freezer over night and if still stuck I'll put a dew strap around the adapter rings and crank the heat up to see if the ring will expand a bit and free it up.
- Has thanked: 173 times
- Been thanked: 615 times
Brian,
Not sure I can help at this stage.....
I’ve successfully use a smear of boot polish on all the treads before using them, It’s worked well for me for over ten years.
Hi all...
An update on my thread issue.
The freezer stay made no difference on the ability to unthread, so returning the assembly to the 'mock' winter assembly conditions was no use.
I dabbed a little canola cooking oil onto some of the exposed threads and after sitting an hour the pieces threaded off with a moderate effort to turn of the strap wrenches...
Thanks for all the suggestions,
