Lunt 60 - 127mm mod
- Has thanked: 20435 times
- Been thanked: 10243 times
Re: Lunt 60 - 127mm mod
I guess the answer is try it with regards the stray light, see if it works. Never tried it myself in an open tube configuration so I don't know.
The mechanics of your drawing will be fine I think.
Regards the f- ratio thing. If the f-ratio is less than that of the collimating lens then there will be vignetting - by my calculations you'll be running at an effective aperture of ~100mm if the collimating lens on the Lunt is f7.5. You may also have issues with the bandpass getting wider across the fov as you get towards the edge, and also the bandpass shifting towards the red as you also get towards the edge of the fov. Basically the centre of the fov will show more detail than the edge.
You can work out how far the 127mm lens needs to sit in front of the Lunts collimating lens - my calcs put it at 543mm.
Also, you will need to unscrew the objective from the Lunt OTA...
Hi John
that is a very fine project. I did something like that 2 years ago and found that it helps if you add another ground plate on top of the "scope" in order to have a firm constellation which is not flexing too much. You can add very easely aperture stops down the light train if you have problems with straylight
Hi John
that is a fantastic construction. It's the way to go. Good luck
sexy time 8)
- Has thanked: 173 times
- Been thanked: 615 times
http://solarchat.solarastronomy.org/ind ... unt-etalon
See message #6249 for a summary....
The lunt objective seems to be around f4.5, so f5 should be OK. Check the distances..
Your set up is no different to an optical bench set-up - it will work. If needs be a black cloth will suppress any reflection issues...give it a go.
The 125 objective wil be pumping 430% more energy into the system....
Me, well I'd play it safe and have an ERF as close to the objective as possible.
You can always use a temporary aperture stop say, 70mm to test out the system.....
Do what Ralph did...just cut an aperture stop from some cardboard and give it a go!!!
Definitely use an ERF
Onwards and Upwards!
I'm 100% sure you'll get there.
Hi John
that lens looks good, very good ;-)
Hi John
that depends only on your skill, not on the lens
John,
I know from Viljo's Lunt 60 mod that it can and does work!
Valery on another thread raises the issues of aberrations in the Lunt single objective being corrected by the front barlow in the etalon assembly, and when used with a doublet - overcorrects...
It's all here, John:
Great scope you and your father made John!
Hi John, apologies for the slow response.
Okey dokes, if you look at the collimating lens in front of the etalon on the Lunt 60 (I think) it is 35mm diameter. So, the object of what we're trying to achieve is to position it so that it intercepts a light cone of the same diameter from the 127mm lens. We can work this out using similar triangles; i'll assume the Lunts collimator is 35mm but you should easily be able to substitute other numbers if it is not.
35/127 = 0.276
0.276 x 700mm = 193mm
So we want to position the lunt collimator 193mm inside the focus of the 127mm lens. But there is an easier way to do this - measure backwards from the back face of the 127mm lens. So, 700mm - 193mm = 507mm... This is the (approximate) gap you will need between the back of the 127mm objective and the front face of the Lunt collimating lens. You will want to have some ability to wiggle this distance a bit - it's only approximate, but it should put you somewhere in the right ball park.
35/127 = 0.276
Yup, 40mm looks like it would work. Just don't unscrew any of those retaining rings, I guess they hold the pressure on the etalon...
Hi John
yes that silicone rubber compound was here too on the threads of the CaK wedge ;-)
Hi John
such is life
such is life
Hi John
Looks great, do I know the lens , looking forward to your first lights
Looks good there John! I look forward to first light
- Has thanked: 8415 times
- Been thanked: 8161 times
Looking good, John. All primed and ready.......
Good luck with your first light.
Hi John
fantastic. eager to see the first lights
Have you got the ERF the wrong way round? One side has the UV/IR coating on, one side does not. Try reversing it and see what happens...
John,
My internal 90mm ERF reflects back through the 150mm objective roughly mid-way between the centre and the edge. Initially I had it tilted too much in my opinion and the reflected heat was impinging on the inside face of the OTA at the rim of the objective. I reduced the tilt purposely to 'let the heat out' as it were.
Clearly, it goes without saying, care has to be taken with the now focussed reflected beam!
I don't know if this will help, but I always have a polarising filter fitted to the nose of my camera so that I can rotate to kill any reflections. My new mod doesn't seem so affected as the original version, but I've left the polariser in place anyhow.
It's the relative distance of that internal ERF compared to everything else then - just gotta play around with it...
Quite possibly, wouldn't surprise me.Asimov wrote:What about the fact that it's running 2 internal ERF's Mark? Reckon the 2 are interacting somehow?
Noooo, definitely don't start taking anything off the 60...
- Been thanked: 4340 times
Hi John...
The modded system looks good...hope you have a successful first light!
