rbenton wrote: ↑Sat Mar 03, 2018 12:41 am
I love the quality of your FD images. So evenly exposed, with just enough limb darkening to look spherical. It also looks like you are not combining two images (surface/proms) but I still see detail in both. Could you share how you get this look?
Still learning.
Randall Benton
www.randallbenton.com
Thanks Randall,
I guess I like a simple process.
1. Double stacked Pressure tuned scope. Pressure tuner gives an even start. I was lucky with the second etalon being onband with nearly no tilt so the image stays even when it is added. PGR Ch3 3.2Mpx gives a full disk with no mosaic with LS60, UV/IR cut filter and tilt adapter to remove Newton's rings.
First tune the scope PT very carefully with an overexposed image to get the filter effect central, then add the non adjusted second etalon with no tilt.
2. Firecapture using gamma to around 1000 to just see the prominences and not overexpose things, histogram 70% ish. 500 frames 37fps.
3. AS2 stack about 10%-20% then PS2 (Photoshop), iterative unsharp mask 30%, 1px, 0 threshold, until it becomes overdone then undo one or two iterations. Convert to RGB, add colour and boost brightness and contrast for the disk and cut red in levels to make the background less hazy red. Check, done.
Whole image processed the same way and only one exposure, which is what I prefer to do just now.
Robert
- P5075583s.jpg (80.94 KiB) Viewed 1691 times
