1st March disk
- robert
- Has thanked: 4 times
- Been thanked: 1275 times
1st March disk
Another clear day with a bitter wind. UK covered in cloud except for NW, extremely unusual, the opposite way round is the norm.
Robert
0301 01_Mar_18_112043_g4_ap541 by robertarnold, on Flickr
Robert
- robert
Re: 1st March disk
Thanks Ewan, yes I agree. Take any chances if possible!
- Ibbo
- Has thanked: 2438 times
- Been thanked: 1650 times
- Christopher
- Has thanked: 33 times
- Been thanked: 34 times
Re: 1st March disk
The weekend weather here looks promising and so does that disk. Nice shot Robert.
Christopher
- Been thanked: 4904 times
- Has thanked: 9149 times
- Been thanked: 6027 times
- rsfoto
- Has thanked: 9417 times
- Been thanked: 5584 times
Re: 1st March disk
Nice nice nice and I have no chance to image at the moment
- Been thanked: 4341 times
Re: 1st March disk
Superb shot Robert
Nice to see some return to activity in your image.
- Has thanked: 17672 times
- Been thanked: 8794 times
Re: 1st March disk
That's a lovely AR developing very unusual to see a gap in the cloud up there
- Has thanked: 20442 times
- Been thanked: 10248 times
Re: 1st March disk
You were lucky with the weather there Robert! A great disk as a result.
Re: 1st March disk
I love the quality of your FD images. So evenly exposed, with just enough limb darkening to look spherical. It also looks like you are not combining two images (surface/proms) but I still see detail in both. Could you share how you get this look?
Still learning.
Randall Benton
www.randallbenton.com
Still learning.
Randall Benton
- robert
Re: 1st March disk
Thanks Randall,rbenton wrote: ↑Sat Mar 03, 2018 12:41 am I love the quality of your FD images. So evenly exposed, with just enough limb darkening to look spherical. It also looks like you are not combining two images (surface/proms) but I still see detail in both. Could you share how you get this look?
Still learning.
Randall Benton
I guess I like a simple process.
1. Double stacked Pressure tuned scope. Pressure tuner gives an even start. I was lucky with the second etalon being onband with nearly no tilt so the image stays even when it is added. PGR Ch3 3.2Mpx gives a full disk with no mosaic with LS60, UV/IR cut filter and tilt adapter to remove Newton's rings.
First tune the scope PT very carefully with an overexposed image to get the filter effect central, then add the non adjusted second etalon with no tilt.
2. Firecapture using gamma to around 1000 to just see the prominences and not overexpose things, histogram 70% ish. 500 frames 37fps.
3. AS2 stack about 10%-20% then PS2 (Photoshop), iterative unsharp mask 30%, 1px, 0 threshold, until it becomes overdone then undo one or two iterations. Convert to RGB, add colour and boost brightness and contrast for the disk and cut red in levels to make the background less hazy red. Check, done.
Whole image processed the same way and only one exposure, which is what I prefer to do just now.
Robert
- marios i.
- Has thanked: 1707 times
- Been thanked: 1125 times
Re: 1st March disk
Very nice!
Marios
Marios
Marios S.Ioannou
Sketcher/Visual Observer
