Solar Animation Tutorial (June 2020)
Moderator: marktownley
Has thanked: 8523 times
Been thanked: 8251 times
There are various ways of doing solar animations and there are already a few excellent tutorials on SolarChat. Here's another option that I use, employing AS!3, ImPPG and GIMP applications that are all free to download.
I'm sure that some of you will have other tricks and tips to share, but for anyone new to this I hope you find my approach to be of some guidance, along with the other methods on this site.
Animation Tutorial.pdf
(1.48 MiB) Downloaded 1462 times
If you try this, please let me know if I've missed any important steps or made any glaring errors so that I can correct accordingly :)
Thanks.
Has thanked: 20732 times
Been thanked: 10427 times
Re: Solar Animation Tutorial (June 2020)
A great resource Stu! lets have a bit of discussion here and then will put in the solar library.
GreatAttractor
Has thanked: 747 times
Been thanked: 757 times
Post by GreatAttractor »
Great tutorial, Stu!
As for coloring the whole animation in GIMP, I've read there are scripts to automate it (i.e apply Curves/other operations to all layers), but haven't got around to trying it.
I noticed you have "CPU + bitmaps" mode enabled in your ImPPG screenshot. Do you get an error message or graphical artifacts when using GPU/OpenGL mode? If so, updating the graphics driver should help.
My software:
My images
Has thanked: 9280 times
Been thanked: 6125 times
Post by ffellah »
Thank you, Stu. Great of you to post this.
Been thanked: 4957 times
Post by eroel »
Stu:
Thanks for the tutorial.
rsfoto
Has thanked: 9677 times
Been thanked: 5750 times
Post by rsfoto »
Hi Stu,
Thanks for the tutorial. Will try the Alignment procedure of ImPPG.
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Thanks, Stu.
Also, I somehow always managed to overlook the batch processing option in ImPPG :oops:
Jochen Maes
Belgium
https://www.jochenmaes.com
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Thank you!
Marios S.Ioannou
Sketcher/Visual Observer
GreatAttractor wrote: Sun Jun 21, 2020 9:30 am I noticed you have "CPU + bitmaps" mode enabled in your ImPPG screenshot. Do you get an error message or graphical artifacts when using GPU/OpenGL mode? If so, updating the graphics driver should help.
No problem running in either mode (no error messages), but I find in GPU mode the image has 'lower resolution' than in CPU+bitmaps mode, as shown in the examples below (magnified views of identically processed Ca K image). Are the features visible in the GPU image the graphical artifacts you mention?
GreatAttractor
I haven't seen this one before, but yes, it looks like the cubic interpolation shader isn't executing exactly how it should on your setup. I'm guessing the saved processed images look the same though for both back ends? Could you send me the stack and ImPPG settings file so I can check on my system?
My software:
My images
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
Thank you Stuart. Will be useful in due course.
Regards
