Today's SUN (20210103) | LUNT60 (single, double & triple stack)
pedro
Has thanked: 14 times
Been thanked: 6683 times
Post by pedro »
WEB LINK:
http://pedroreastrophotography.com/sun_ ... 21-01.html
Solar imaging session (20210103) | Pedro RE'
LUNT60 Single, Double, & triple Stack (SM60/SM40)
GS3-U3-28S4M, Takahashi EM-400
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
IMAGING SETUPS
SUN (20210103) H-alpha (09:30 UTC). LUNT60, TS SM60/SM40, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210103) H-alpha (09:30 UTC). LUNT60, DS SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210103) H-alpha PROMS (09:30 UTC). LUNT60, DS SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210103) H-alpha PROMS (09:00 UTC). LUNT60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210103) H-alpha PROMS (09:00 UTC). TV101 F/5.4, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210103) CaK PROMS (09:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, PGR GRASSHOPPER 3 GS3-U3-28S4M
SUN (20210103) WL, CaK & H-alpha (09:00 UTC). TV101 F/5.4, LUNT 1200 CaK Module, SM60, BF30, PGR GRASSHOPPER 3 GS3-U3-28S4
rsfoto
Has thanked: 9677 times
Been thanked: 5750 times
Re: Today's SUN (20210103) | LUNT60 (single, double & triple stack)
Post by rsfoto »
Hola Pedro,
That is an interesting comparison between single, double and triple stack. Thank you.
Been thanked: 4957 times
Post by eroel »
Pedro:
Interesting comparison of single double and triple stacks.
Feliz año nuevo.
EGRAY_OBSERVATORY
Been thanked: 4900 times
Post by EGRAY_OBSERVATORY »
That triple-stack certainly well-increases the contrast Pedro. Well done as usual.
Regards
Has thanked: 17807 times
Been thanked: 16940 times
Post by DeepSolar64 »
I don't see people triple stack that much. I bet visually the image would be quite dim. It results in very good contrast on your images though!
pedro
Post by pedro »
Thanks guys
I did not tried these combos visually. The sun will be very dim as James mentions
Has thanked: 17888 times
Been thanked: 8887 times
Wow!! that triple stack is a killer shot!! delicious :bow :hamster: can you post exposure times for all three?
JochenM
Has thanked: 1200 times
Been thanked: 1619 times
Post by JochenM »
Interesting side-by-side comparison there, Pedro. Must have been a bit of effort to get all three etalons perfectly tuned.
Out of curiousity, how much did that triple-stack influence the exposure times?
Jochen Maes
Belgium
https://www.jochenmaes.com
pedro
Post by pedro »
Thanks Jochen
The triple stack has a huge influence in the exposure time. I had to increase gain, usually I never do that
The result is interesting. I also used the the autostakkert flat field option (it is not easy to adjust the three etalons - two front-loading and one end-loading)
Has thanked: 20732 times
Been thanked: 10427 times
Great results Pedro! I tried the triple stack route a good few years ago now, I like the contrast that it gives, but for me the increase in exposure time and fiddly tuning meant I never pursued it.
Astrophil
Been thanked: 581 times
Post by Astrophil »
Pedro, the triple stack is quite impressive.
Phil
Has thanked: 64 times
Been thanked: 4406 times
Post by MapleRidge »
These are excellent images and your triple stack turned out much sharper than mine...well done :bow
Has thanked: 8523 times
Been thanked: 8251 times
Excellent, Pedro. I can only imagine the challenges tuning all three etalons :)
Great result though.
robert
Has thanked: 4 times
Been thanked: 1275 times
Post by robert »
Superbly thorough. (as usual!) Great to see
Robert
pedro
Post by pedro »
Thanks again guys
As I mentioned before it is hard to tune all three etalons. I guess I will stick with double stack
Has thanked: 1 time
Been thanked: 2725 times
Post by christian viladrich »
Hello Pedro,
This is excellent. A big THANKS for sharing this.
Looking at these, I found the triple stack image a bit less crispy than the others. My understanding is that the triple stack samples a layer higher is the chromosphere, and the higher the layer the less crispy are the details. We can see this phenomenum in professional images too.
Do you thing that a difference in seeing / exposure time could also be an explanation ?
Christian
pedro
Post by pedro »
Thanks Christian
I agree completely, the triple stack images are less crisp. I have to add that the third etalon used was a pre-meade SM40 with a lower aperture.
JohnW
Been thanked: 1624 times
Post by JohnW »
Thanks Pedro - an interesting set of comparison images. Must have taken a lot of tuning. Regards, John W.
pedro
Post by pedro »
Thanks John
It did take a lot of tuning
dhkaiser
Has thanked: 1407 times
Been thanked: 899 times
Post by dhkaiser »
STOP with the triple stacking. You will influence my solar expenditures!
Really sharp, well done.
Dan
South central Indiana
USA
marios i.
Has thanked: 1707 times
Been thanked: 1125 times
Post by marios i. »
Beautiful images Pedro as always.
Marios S.Ioannou
Sketcher/Visual Observer
AstroBees
Has thanked: 171 times
Been thanked: 193 times
Post by AstroBees »
Great images and very informative.
Lunt 80mm Ha single stack with a ZWO 1600mm cooled camera and iOptron Z25EQ mount.
Explore Scientific ED 127mm APO with Baader ASTF Solar Filter and Celestron CGX mount.
pedro
Post by pedro »
thanks again guys
