A few prominence animations.
- Has thanked: 13 times
- Been thanked: 122 times
I have never really tried animations before. Here are a few taken over the last couple of weeks done with the Altair 102 ED-R and Daystar Quark Chromosphere. The timelapse in each case is 60 minutes. Sometimes there are internal reflections or interference patterns which become evident when the gain is turned up for fainter proms. So this is an issue I'm trying to sort out with flats.
BRIAN
Caithness, Scotland.
Double stack PST, Lunt CaK B600, Daystar Quark Chromosphere
with Altair Astro 102 ED f.7 Refractor and 60 EDF f.6 Refractor.
Celestron Nexstar 8SE.
QHY5III678M
QHY5III678M
- Peterm
- Has thanked: 1825 times
- Been thanked: 1583 times
Re: A few prominence animations.
Well done Brian there are some nice features captured in those animations. Did you use IMPPG and the Align Image Sequence feature under Tools?
Lunt 80Tha S/S & D/S / B1800; Quark Chromosphere; SkyWatcher 120 Evostar; Celestron SE6; Celestron AVX; Berlebach Planet; ZWO174MM & 432MM & 533MM; Powermate 5X; Lunt Solar Wedge; Hinode SG; Airy Labs SSM
Astrobin: https://www.astrobin.com/users/PeterM/
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- solar
- Has thanked: 257 times
- Been thanked: 1446 times
You have some nice details in there Brian. Flats will help a lot with the uneven illumination.
Vixen 130ss SolarMax 90 BF30 EQ6 Pro, LX200 14, C8 CG5, Megrez80, Lunt 100 DS. EQ 8
ASI 120mm 290mm 432mm Lunt B1800 Cal-K + other stuff.
Skywatcher 150mm PST Mod2
- Has thanked: 17996 times
- Been thanked: 17152 times
Brian,
Very well done. Very professional in appearance. Did you notice the coronal rain in the first one?
- Has thanked: 1923 times
- Been thanked: 1365 times
Great detail
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
- Has thanked: 21003 times
- Been thanked: 10626 times
Good cinema there Brian! definitely give the image align feature a go in ImPPG
- arnedanielsen
- Has thanked: 6389 times
- Been thanked: 7449 times
Very nice Brian! Flats and image align should are the next steps to improve the quality.
Thanks everyone! I tried the image align in ImPPG but unfortunately my tracking was a bit too wayward and the program didn't do it for me. I ended up manually aligning in Registax 5, doing a batch process in Photoshop to blacken the disc and then finishing up with PIPP for the final animation.
BRIAN
QHY5III678M
QHY5III678M
- Has thanked: 18146 times
- Been thanked: 8947 times
I asked that exact same question in the Software section, what do you do when ImPGG align doesn't work? I got no responses
I used to use Registax 5 but it no longer works on my computer
- rigel123
- Has thanked: 8705 times
- Been thanked: 8961 times
It can be extremely difficult to align frames that have a blown out disk with bright proms and the seeing wasn't great. The software has nothing to "grab" onto if the surface is bubbling. If there aren't too many frames in the animation I manually align them in Photoshop in that case.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- solar
The way to use ImPPG for Alinement is to leave some detail on the disc. The information is still in the proms and is processed out later. Try different amounts and you will soon get the hang of it Brian.smerral wrote: ↑Wed Mar 20, 2024 8:33 pm Thanks everyone! I tried the image align in ImPPG but unfortunately my tracking was a bit too wayward and the program didn't do it for me. I ended up manually aligning in Registax 5, doing a batch process in Photoshop to blacken the disc and then finishing up with PIPP for the final animation.
Thanks Solar, i will give it a go.The way to use ImPPG for Alinement is to leave some detail on the disc. The information is still in the proms and is processed out later. Try different amounts and you will soon get the hang of it Brian.
BRIAN
QHY5III678M
QHY5III678M
