AR13685 The Movie - 10 hours 33 minutes timelapse with 204mm refractor in H-Alpha 18th of May 2024
- arnedanielsen
- Has thanked: 6954 times
- Been thanked: 8000 times
Dear friends,
This is by far my biggest timelapse project to date. A total of 1878 recordings was made between 06:41 and 17:14UT on May 18th 2024 under variable conditions. Each recording was 18 seconds long with a framerate of 66fps (1188 frames) and 2 seconds delay between each recording resulting in a total of approx 3,7TB of data.
The recordings where obtained through an iStar Asteria TCR 204-12 R35, with an Altair Astro 115mm TRIBAND H-Alpha D-ERF, Baader 35nm H-Alpha, Baader SunDancer II 3x Telecentric System TZ-3S, DayStar Quantum 0,4å PE and Player One Apollo-M Max mounted on a Sky-Watcher AZ-EQ6 PRO and guided with Hinode SolarGuider.
The best 200 frames from each recording was stacked in AutoStakkert!4 before they were aligned and sharpened in ImPPG. Change in light intensity due to variable transmission and athmospheric distinction was corrected using GBDeflicker. A total of 126 frames had to be tossed due to passing clouds or wind shaking the scope resulting in 1752 fames making it into the final animation which was created using PIPP at 15fps. This effectively compressed the 10 hours 33 minutes of duration down to just 1 minute 56 seconds.
Click on the image to view the timelapse on AstroBin.
Thanks for looking
Thanks for looking
- Martin_S
- Has thanked: 1094 times
- Been thanked: 3261 times
Re: AR13685 The Movie - 10 hours 33 minutes timelapse with 204mm refractor in H-Alpha 18th of May 2024
W0ow that's an amazing timespan for an animation Arne, well done.
- rigel123
- Has thanked: 9368 times
- Been thanked: 9588 times
Saw this on FB and my jaw dropped. I can’t imagine processing that much data! Great, subtle activity during the entire animation.
Warren
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
Baader Photographic Film
ASI174MM
Skyris 236M
Player One Saturn-M SQR
Lunt LS60T DS
Orion ED80T CF
Meade ETX LS6
Lunt CaK BF1200
Lunt WL Wedge
ASI174MM
Skyris 236M
- H-Alpha
- Has thanked: 1756 times
- Been thanked: 1042 times
Dear Arne, is this the world record in solar animation time span????
Fantastic work!
When the seeing is getting better the quality is superb.
Congratulations and thanks for sharing.
Best wishes,
Alexandros
Fantastic work!
Best wishes,
Alexandros
Alexandros
Greece
Greece
- Has thanked: 9859 times
- Been thanked: 6568 times
An amazing technical accomplishment and a beauty, Arne ! Lots of work but te result makes it worth it.
Congratulations
Congratulations
- Has thanked: 21978 times
- Been thanked: 11201 times
That's excellent cinema Arne!
- nicspenceryork
- Has thanked: 6590 times
- Been thanked: 1524 times
Wonderful to see this animation Arne. We get the benefits of watching all that wonderful movement without any of the hard work! My highlights were at 47 seconds on the right at middle height and the final 10 seconds around the big spot. Fascinating.
Thank you
Nic
Thank you
Nic
- Peterm
- Has thanked: 2006 times
- Been thanked: 1773 times
Arne, what to say other than epic, amazing, wonderfully processed and beautifully presented! My jaw is also somewhere on the floor. OMG Terrabytes of data...now I am really scared! BravO!
Lunt 80Tha S/S & D/S / B1800; Quark Chromosphere; SkyWatcher 120 Evostar; Celestron SE6; Celestron AVX; Berlebach Planet; ZWO174MM & 432MM & 533MM; Powermate 5X; Lunt Solar Wedge; Hinode SG; Airy Labs SSM
Astrobin: https://www.astrobin.com/users/PeterM/
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- arnedanielsen
Thank you very much for taking the time to view and comment everyone!
- DanielBrousseau
- Been thanked: 159 times
Incredible, we really see the importance of the seeing, our worst ennemy.
Tanks Arne,
Tanks Arne,
Phantom 140 f/6.5, SW newton 254mm f/5, Quark Chromosphere, Lunt 60mm Universal, Baader ceramic wedge, ASI174 mono, ASI294 mono, ASI290 mono,
Sherbrooke, Québec, Canada
- Has thanked: 585 times
- Been thanked: 380 times
Arne,
I've not seen too many animations at that magnification let alone duration. So well done!
I've watched this over and over, the activity is absolutely fascinating. Glad you were able to capture and share this.
Thanks!
Wayne
Thanks!
Wayne
Lunt LS50THa, B600, single stack
William Optics Z61, William Optics Z81 refractors
DayStar Quark Chromosphere, w/1.25" ZWO UV/IR filter
Baader solar film filter
ZWO ASI178MM, ASI174MM
8x32 SunOculars
8x32 SunOculars
- rsfoto
- Has thanked: 10511 times
- Been thanked: 6144 times
Well done
- arnedanielsen
Thank you very much Daniel, Wayne and Rainer!
- Been thanked: 2003 times
So envious you got that scope still! Killer results and worth the hassle to get that up and running.
- Has thanked: 18621 times
- Been thanked: 17772 times
WoW, Arne! Absolutely stunning work. So much to see there. My longest solar visual session is just under ten hours and you have me beat and did an animation of it! My hat is off to you!!
James.
James.
- Has thanked: 8875 times
- Been thanked: 8646 times
Amazing result, Arne. I admire your tenacity…well worth the effort. Brilliant
- Has thanked: 1 time
- Been thanked: 2814 times
Fantastic animation
I was wondering whether you could add the time (HH:MN:SS) information on each frame ?
I know Paul (Banjo) has developped a short code for this. Maybe it could make it available to you.
- arnedanielsen
Thank you very much for taking the time to view and comment Simon, James, Stu and Christian! Much appreciated!
Simon: I was very unsure if I was going to buy it as I had no opportunity to test it on beforehand and the transport cost were astronomical. I am however very glad I did take the chance and buy it.
James: When it's clear and I'm home any way it mostly runs by itself... just have to check that everything is working every now and then.
Stu: I had to look that word up! :-) Thanks!
Christian: I will try to have a look into that.
Arne. Extended visual sessions are the same way. You certainly do not stay behind the eyepiece. You check the sun every few minutes and make sure the kit is ok. In between you do other more often needed things. It is a multitasking game.
Yeah i was eyeballing it too for weeks, i was trying to pull some favors from friends in the telescope industry to check it but by the time i got anywhere, some guy purchased it!
arnedanielsen wrote: ↑Sun Jun 02, 2024 6:12 pm Simon: I was very unsure if I was going to buy it as I had no opportunity to test it on beforehand and the transport cost were astronomical. I am however very glad I did take the chance and buy it.
- Has thanked: 65 times
- Been thanked: 4599 times
Arnie...
This is a fabulous animation and I congratulate you for the time and effort to capture and process this amount of data. Well done
You list a 115mm ERF...is the scope reduced to 155mm aperture or is it placed internally but still getting full aperture through it? If you posted more detail on the scope earlier I missed it with the limited time to browse these days
- arnedanielsen
There's always "some guy" :-)Simon2940 wrote: ↑Sun Jun 02, 2024 9:45 pm Yeah i was eyeballing it too for weeks, i was trying to pull some favors from friends in the telescope industry to check it but by the time i got anywhere, some guy purchased it!
I was on vacation in Japan when I stumbled upon the ad. I was considering waiting till I got back home in order to investigate a bit more before deciding, but luckily I didn't! :-)
- arnedanielsen
Thank you very much, Brian!MapleRidge wrote: ↑Mon Jun 03, 2024 2:10 am Arnie...
It's correct that's an Altair Astro 115mm TRIBAND D-ERF. The scope is an open truss tube, making it very easy to place it further down the light cone.
- Been thanked: 5096 times
Arne:
Superb animation, the longest I have seen.
Send you my best wishes and thanks for sharing such a work.
Best regards.
Best regards.
- KMH
- Has thanked: 712 times
- Been thanked: 906 times
Wow - that's a terrific accomplishment! And a great looking scope!
Kevin
Kevin
That is a nice looking scope, Arne.
- arnedanielsen
Thank you very much for your kind words, Eric, Kevin and James!
