My very first attempt at the Helium D3 line using the 72ED and Sol'Ex SHG. Using Valerie Desnoux INTI free line routine to reconstruct the image I then used Photoshop CS2 to flip/rotate to correct orientation and try to remove some of the noise.
Alun
Helium D3 07/04/23
- Alun_H
- Has thanked: 648 times
- Been thanked: 622 times
Helium D3 07/04/23
Lunt 50THa solar scope
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 18146 times
- Been thanked: 8947 times
- Alun_H
Re: Helium D3 07/04/23
Thank you Alexandra. I think these lines are artifacts left after the subtraction of the continuum image,I played around with the Polynomial settings in INTI and these lines would change position but then the contrast in the image would drop as the shift would pull it off band. Need to do more Helium D3 imaging to learn more about using INTI free line and its proper settings.
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
- Has thanked: 57 times
- Been thanked: 1231 times
- Alun_H
Thank you John.
INTI software and PDF download giving complete instructions on Helium D3 http://valerie.desnoux.free.fr/inti/ http://valerie.desnoux.free.fr/inti/INT ... mD3_EN.pdf
Alun
Alun
Lunt CaK B12 module
Sol'Ex SHG
Lunt CaK B12 module
Sol'Ex SHG
