Easy Peasy PST Mod
- Oh, I get it now!
- Has thanked: 7 times
- Been thanked: 59 times
Easy Peasy PST Mod
I have just finished my first solar season with my PST mod which this group helped me to build. It seems to work very well and you can see a compilation of my captures at https://youtu.be/q2_tTYrpWwQ
The mod is very simple and here are the steps:
1. Remove original 40mm PST objective.
2. Mount 2" Baader 7nm Ha filter to front of PST using 52>48mm step down ring.
3. Mount F10 OTA over PST tube to focus at 200mm past etalon.
I tested the concept using a Celestron Powerseeker 70AZ OTA. I had to remove the last baffle which just pushes out but I did not have to cut the tube.
Once concept was proved I then used a Celestron Cosmos 90GT OTA for the final configuration. Again, baffle removed and tube not cut. Below are some fotos to show the design.
Dave
- Has thanked: 21003 times
- Been thanked: 10626 times
Re: Easy Peasy PST Mod
Nice mod!
- Has thanked: 48 times
- Been thanked: 1543 times
This interesting configuration could in principle also be used for the CaK PST. The 40mm optics is not as much of a limiting factor at the shorter wavelength, but it's probably a quick and easy way to get 70mm to 80mm aperture. The CaK PST has a quite nice bandwidth (I think a little better than the Lunt CaK).
- Has thanked: 57 times
- Been thanked: 1231 times
- Has thanked: 1923 times
- Been thanked: 1365 times
That is great
Rich
Lunt 60mm SS, Daystar Quark Chromosphere,
Antlia wedge,Lunt wedge
Hello - Can I use a 2" Lumicon LF3090 filter for this mod? I can't seem to find passband info on it? Please advise. Thank you.
Not much info out there on it. Is it a coloured glass type filter or does it have a dichroic coating?
Thanks for the reply - looks like a colored filter to me. I think I'll just keep on the lookout for the Baader filter.
- The Sun?
- Has thanked: 6 times
- Been thanked: 6 times
Forgive my ignorance, but am I correct in reading this basically converts a 40mm objective to a 90mm objective, giving much better resolution and “simply” moves the etalon further back in the light path? If so, what a neat idea! I had heard that some of the solar scope manufacturers were doing something like this…but had no clue folks were trying that on their own.
- Oh, I get it now!
The AOKswiss website http://www.aokswiss.ch/ayo/pst.html states that
A simple way to protect the filter is to use a good normal red filter with 48 mm thread (as for a 2" eyepiece). This works up to max. 4" scopes and f : 10 (mounting on the adapter).
I think this means that you may be able to use the Lumicon if your objective is smaller than 4".
I have been using my mod with the Baader filter for a few months now and it seems to work fine with no problems. You can see some of my solar animations I made with it here : http://starrydave.com/?page_id=1330
Dave
Sounds sensible to me
- Oh, I get it now!
That's the idea. I removed the stock 40mm objective and replaced it with a 90mm f10 OTA. I now have a 90mm f10 h-alpha scope that cost less than £1000. Also, my design means that the PST and donor scope are undamaged and can be easily restored to their original condition.Flying dinosaur wrote: ↑Wed Mar 20, 2024 7:22 pm Forgive my ignorance, but am I correct in reading this basically converts a 40mm objective to a 90mm objective, giving much better resolution and “simply” moves the etalon further back in the light path? If so, what a neat idea! I had heard that some of the solar scope manufacturers were doing something like this…but had no clue folks were trying that on their own.
Dave
