Clear and Cold
Moderator: Montana
- Has thanked: 65 times
- Been thanked: 4527 times
Clear and Cold
Good day everyone...
Clear and cold refers to Friday night here (Jan 20th UT)...it was -18C when I went to the observatory. I was surprised to see that the skies had cleared after supper and the forecast was only for a short clear period but I hadn't imaged Jupiter in some time so I wanted to take advantage of the opportunity.
The seeing was remarkably good considering the air temp, and I ran a series of RGB, IR and CH3 images over a 2 hour period. The better set of RGB, IRGB, and IR680nmm images are posted bellow. These were taken with the C14 @ f18 with the ASI462MM camera: I also set up the ASI432MM camera to do some lunar images since the clear skies continued on, but before moving to the moon I used that camera (same optical setup as used for Jupiter) and grabbed this IR image of Jupiter and its moons which were aligned to the east of the planet: I used the ASI432MM camera (with the C14@f16 and IR680nm filter) to image some of the lunar features along the terminator. The live view almost looked as though I was flying over the moon That's all for my Friday night session...hope you enjoy the views!
- Has thanked: 18400 times
- Been thanked: 9046 times
Re: Clear and Cold
I keep looking at Jupiter and the Moon and thinking I should get the telescope out but I get put off with the cold. However, now I laugh at myself, it's not that cold here!
Well done Brian, those pictures of the Moon are just incredible
Re: Clear and Cold
Kevin, cte, and Alexandra...
Thanks for your feedback on these images...very much appreciated
This was really the first truly 'cold' snap that we have had so far, but the wing back to warmer weather is starting again as it was above freezing today and rain forecast for the next few days.
I have not had great luck pushing the focal length much more than what I have adopted as a standard the past few years. In night with really good seeing I might squeeze more out of the scope but on this night it was good considering cold, but the IR details are not as good as other nights.
- Has thanked: 8713 times
- Been thanked: 8448 times
Re: Clear and Cold
Awesome images, Brian. The Moon images are breathtaking.
Re: Clear and Cold
Thanks Stuart, your feedback is always appreciated
- rigel123
- Has thanked: 8945 times
- Been thanked: 9170 times
Re: Clear and Cold
Great images Brian!
Re: Clear and Cold
Thanks Warren
The cold has passed and now well above normal...thanks to la Nina and climate change we go from one extreme to another
- pedro
- Has thanked: 14 times
- Been thanked: 6839 times
Re: Clear and Cold
fantastic lunar images Brian. Your C14 is a great instrument. I had one a long time ago and I regret lending it to a friend...
Pedro Re'
Re: Clear and Cold
Thank for your comments Pedro...much appreciated
It doesn't sound like your 'loan' turned out very well ???
Re: Clear and Cold
I was going to ask that too, did they run away with your loan? that's theft, they are a lot of money
