Aurora 13th / 14th February
Moderator: Montana
- Has thanked: 21012 times
- Been thanked: 10632 times
Hi All.
Following my ad hoc aurora timelapse from the early hours of tuesday 13th, the forecast - both weatherwise and aurora wise was good for Tuesday night, with a thin crescent moon not having too much impact, clear skies with temps down below -10c and the KP index forecast 4+. After camera misunderstandings in the early hours, I had practiced my setting up routine and was ready.
We ate evening meal as it was going dark, and then I was on point duty, eyes on the skies for the first signs of the green stuff. Absolutely nothing was happening, I took test shots with the camera to see if it was below naked eye visibility, but no, nothing. By about 10pm I was cursing and cussing as nothing had happened, despite the auroral oval suggesting something should. Mrs T got fed up and went to bed, so I sat with the ligths out next to my big panorama window perusing the web with a side eye on the sky.
Just before midnight I was was concious the sky suddenly lit up. I was out in a flash, but the aurora was doing it's usual trick of making me stand with my mouth wide open immersed in the spectacle. Tearing myself from Medusas glare I went and grabbed the camera and started a timelapse - 10mm f4, 15 secs, iso 3200. The intervalometer just kept the camera firing away.
11pm-aurora-13022024 by Mark Townley, on Flickr
The brighter moments were lighting up the landscape, and this is only a KP4. The sky changes to a more diffuse green glow as it subsides.
Fired up by this, I decided I was in for the night and the coffee went on.
With the aurora now faded I decided on a timelapse of the milky way, however after shooting it and checking it back realised not much was visible as the camera lense (camera and tripod) was now heavily coated in frost. Nothing short of a dew heater was getting it off the lens. Then, just to torment me, it was about 4am at this point, the aurora decided it was putting on one last blast. Weighing things up I swapped for the cameras stock 18-55mm lens and shooting 18mm f4, 15 secs, iso 3200 went for another run.
4am-aurora-14022024-small by Mark Townley, on Flickr
It worked, even with a smaller field of view. By 5am it had all subsided again, and there is only so much coffee you can drink, so, I called it a night.
Today is snowing, tomorrow is whale watching, however Thursday night offers clear skies, even if the forecast for aurora aint great. Either way, if I can see the sky I will be looking!
Hope you like!
Hope you like!
- Has thanked: 9884 times
- Been thanked: 5879 times
Re: Aurora 13th / 14th February
Hi Mark,
Beautiful time lapses
- Has thanked: 65 times
- Been thanked: 4470 times
These are superb animations Mark...well done
- Has thanked: 18146 times
- Been thanked: 8949 times
Wow!!! these are just incredible You are also amazing being able to stay awake that long
- nicspenceryork
- Has thanked: 6201 times
- Been thanked: 1372 times
- rigel123
- Has thanked: 8705 times
- Been thanked: 8968 times
Gorgeous Mark! I haven’t done an all nighter in years!
- Has thanked: 8604 times
- Been thanked: 8334 times
Superb captures, Mark.
FYI, here are some data from my magnetometer (granted, from here in the UK, not Iceland) which show the pulses of geomagnetic unrest over your observation period.
- Been thanked: 1651 times
Well done Mark - I really like your story and images. It was worth the effort.
John W
John W
Stuart, great to see your recording of the time span with your magnetometer. Well done
Thanks everyone for the kind words. Sadly this has been the only aurora seen all week, and not through lack of me getting up out of bed every night and checking.
Thanks for the graph Stu, looks like my 2 animations correspond to the 2 spikes at 00h and 04h on the 14th respectively.
Last day here today, so, an afternoon of hot tub and beers in a howling gale! Sounds strange, but I prefer it to going back to work on Monday
