Took a quick pic of the moon and then started the comet with a bunch of folks interested in what I was doing in a very public park! It was fun and I need to better learn using Pixinsight for color images as the Seestar images always debayer as very GREEN!!
Moon
Comet 12P/Pons-Brooks
Night of the comet 3/14/2024
Moderator: Montana
- rigel123
- Has thanked: 8705 times
- Been thanked: 8967 times
- Has thanked: 18146 times
- Been thanked: 8948 times
Re: Night of the comet 3/14/2024
Wow!!!
what time did you image the comet and was it very low down?
- Has thanked: 9867 times
- Been thanked: 5874 times
Hi Warren,... I need to better learn using Pixinsight for color images as the Seestar images always debayer as very GREEN!!
That is very normal on RGB images. You need to do a White balance.
But I have to say that this is interesting as when I
do from time to time OSC images I never had this problem.
Can you put somewhere the raw image in order to play with it?
Thanks Rainer
- rigel123
Thanks Alexandra and Rainer! I imaged it between 8:15 - 9:00 EDT and it was probably 20 degrees above the horizon when I started and the sky was bright!
Rainer, I’ll try to a Star Aligned Master and a Comet Aligned Master to let you play with. My cousin who often uses his Seestar and processes it in PI says they are always very green out of the Seestar
- rigel123
I finally figured out Pixinsight and then finished off in Photoshop where I felt comfortable combining the images (starless and stars only) and stretched the different histograms separately since many of the subs were taken at sunset so had a huge gradient which you can tell is at the bottom of this image.
Hi Warren,rigel123 wrote: ↑Mon Mar 18, 2024 8:54 pm I finally figured out Pixinsight and then finished off in Photoshop where I felt comfortable combining the images (starless and stars only) and stretched the different histograms separately since many of the subs were taken at sunset so had a huge gradient which you can tell is at the bottom of this image.
Well done. In the latest PixInsight version there is a process called Gradient Correction and it is a pretty powerfull tool. Just test it and as a tip put Smooth at 0 for a start.
- rigel123
Thanks Alexandra and Rainer, I’ll check out that process.
- pedro
- Has thanked: 14 times
- Been thanked: 6767 times
I used the gradient correction and also GraXpert to correct my Seestar 12P/Pons-Brooks images. It works fine
Pedro Re'
