Hi all.
When I was observing the sun on my Coronado DS90, a bolt fell out and was loosely tightened.
If you tighten it too much, there will be no tilt, I need to correct the tilt at least a little bit.
I found two bolts that fit just right with this knurling from furniture and changed it a little.
I'll show you some pictures of how I did it.
Maybe it will come in handy.
Alexander.
Replacing the bolts on the Coronado DS90 tilt adapter.
- IMG_20240325_120825..jpg (82.52 KiB) Viewed 214 times
Re: Replacing the bolts on the Coronado DS90 tilt adapter.
I used a lathe.
- IMG_20240325_121333.jpg (88.86 KiB) Viewed 212 times
Prepared two bolts.
- IMG_20240325_131216....jpg (78.78 KiB) Viewed 211 times
I screwed them into place.
- IMG_20240325_130810.jpg (40.15 KiB) Viewed 210 times
Here is the result now I do not worry that it will fall out.
- IMG_20240325_130718.jpg (57.75 KiB) Viewed 208 times
Now it's ready.
Thanks for watching.
- IMG_20240325_130957.jpg (53.16 KiB) Viewed 206 times
- Has thanked: 9905 times
- Been thanked: 5890 times
Well done
- Has thanked: 21016 times
- Been thanked: 10633 times
Looks like it works. Do you know what the thread size is?
Hi, Mark.
Looks like number 28 but I'm not 100% sure. but it works, it lightly I have it screwed on without force.
Alexander.
Alexander.
- IMG_20240326_124708.jpg (73.08 KiB) Viewed 134 times
