Sunday Sunshine
- Has thanked: 65 times
- Been thanked: 4565 times
Sunday Sunshine
Good day everyone...
The weather forecast for Sunday (April 28th) called for clear skies in the morning with increasing cloud and showers possible in the afternoon. The sun did arrive in the morning but the clouds came in early and the rain started and hasn't let up yet It has put a damper on the hopes to start getting some crop in a bit early here but not hurting yet.
I had a good start to imaging with FD in Ha, CaK, WL, and G-band but I was fighting the clouds when I tried to do higher resolution Ha. It would have been nice to have more item as there were 14 AR's identified, as well as several filaments a a few proms to add to the potential target list. The FD images are first, with the WL, G-band, and CaK all imaged through the Orion EON130 OTA with the ASI1600MM camera. The WL image used a Lunt Solar Wedge/Baader Continuum filter, the G-Band used the Altair 430nm/2nm filter, and the CaK was imaged through the Lunt B1800CaK module. Both the G-band and CaK had the scope stopped to 90mm: While the G-band filter was in use, I changed to the ASI462MM camera and a 3x barlow to image the AR's in higher resolution: I moved to the Lunt solar scope to start Ha imaging and it was around this time the clouds started to drift in. The first is the Ha FD, usign a 1.6x barlow ahead of the ASI1600MM camera: I added the 3x barlow to the Lunt scope to get a bit more image scale, but cloud ruined many of the captures and I was only bale to get a few frames to make a mosaic of the western disk and AR3654/3657 which was the star of the show: There was a nice prom arching across the western limb but cloud really messed with the ability to recover much of an image but this was what I did catch...lots of artifacts to ignore This covers the session form April 28th, I hope you like the results!
- Has thanked: 21641 times
- Been thanked: 11005 times
Re: Sunday Sunshine
Nice results Brian, that CaK full disk has more contrast.
- Has thanked: 8757 times
- Been thanked: 8509 times
Re: Sunday Sunshine
You had a good session, Brian. Nice results.
- rigel123
- Has thanked: 9080 times
- Been thanked: 9309 times
Re: Sunday Sunshine
Excellent session Brian! Some amazing details in those G band closeups!
Re: Sunday Sunshine
Mark. Stuart, and Warren...
Thanks for all of your feedback and comments...always appreciated
Mark, I didn't do anything much different on the CaK at capture bu I may have made more adjustments post processing is Photoshop
- Has thanked: 3296 times
- Been thanked: 2401 times
Re: Sunday Sunshine
Nice collection Brian, glad you could take some shots before the rain.
Triband C9.25
H-a: 2x Lunt40 rear mounted
Cameras: imx432 + imx462
Barlows:
-2x Gerd Düring 2.7x
-2x TMB 1.8x
Barlows:
-2x TMB 1.8x
Re: Sunday Sunshine
Dennis, Kevin and Drew...
Thanks for your comments on the session...much appreciated
- Peterm
- Has thanked: 1972 times
- Been thanked: 1729 times
Re: Sunday Sunshine
Wonderful set of images Brian.
BOSS team: https://www.scienceinpublic.com.au/medi ... ia-release
- Has thanked: 9661 times
- Been thanked: 6437 times
- Has thanked: 2577 times
- Been thanked: 5106 times
Re: Sunday Sunshine
Peter, David, Franco and Maurits...
Thanks fro your comments guys
- Has thanked: 18366 times
- Been thanked: 17534 times
Re: Sunday Sunshine
Brian, I always enjoy your work and all looks good here but my favorites are the full disc CaK and the Gband closeups.
Good luck with the weather and the crops.
Re: Sunday Sunshine
Thanks James
Re: Sunday Sunshine
You are welcome, Brian.
- pedro
- Has thanked: 15 times
- Been thanked: 6893 times
- Has thanked: 6769 times
- Been thanked: 7732 times
